Hi!. I wonder if anyone can help me with this. When I use the SSS in Arnold everytime I get this green tone when there is a contact area with another surface. you can see in the ears a little bi as well. How can I get rid of this
Solved by mspeer. Go to Solution.
Hi!
Check and correct Subsurface -> Scale (should be smaller to remove this effect).
You can also correct this with object size and Scene Scale in Render Settings.
Hi @fsuung
I'm just checking in to see if you need more help with this. Did the suggestion that @mspeer provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Yes he Did! I Paint a map to control the weight of the SSS. However I an not sure why this happens especially when 2 surface come into contact. Because the scale was right.
this is really annoying, i encountered this issue too, i've tried everything until changing render scaling unit, etc, it didn't work!
