Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Arnold aiStandarSurface SSS green tone
7 REPLIES 7
Message 1 of 8
fsuung
3382 Views, 7 Replies
Hi!. I wonder if anyone can help me with this. When I use the SSS in Arnold everytime I get this green tone when there is a contact area with another surface. you can see in the ears a little bi as well. How can I get rid of thisScreenshot_1.png
7 REPLIES 7
Message 2 of 8
mspeer
in reply to: fsuung
Hi!
Check and correct Subsurface -> Scale (should be smaller to remove this effect).
You can also correct this with object size and Scene Scale in Render Settings.
Message 3 of 8
sean.heasley
in reply to: mspeer
Hi @fsuung
I'm just checking in to see if you need more help with this. Did the suggestion that @mspeer provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 4 of 8
fsuung
in reply to: sean.heasley
Yes he Did! I Paint a map to control the weight of the SSS. However I an not sure why this happens especially when 2 surface come into contact. Because the scale was right.
Message 5 of 8
in reply to: fsuung
this is really annoying, i encountered this issue too, i've tried everything until changing render scaling unit, etc, it didn't work!
Message 6 of 8
i got this issue too and it didn't work...
Message 7 of 8
viker8rd
in reply to: mspeer
Scene Scale in Render Settings?
where is this? I don't see it
Message 8 of 8
mspeer
in reply to: viker8rd
Hi!
@viker8rd
Render Settings:
System > Render Settings > Render Unit
System > Render Settings > Scene Scale (When Render Unit is set to "Use Custom Scaling")
Technology Administrators
