Dear all,
Please help me, my Maya app keep showing ACWebBrowser after reinstalling Maya new version (2019). I already do all to fix it from this link https://forums.autodesk.com/t5/maya-forum/what-is-acwebbrowser-exe-and-how-do-i-disable-it/td-p/6285...
But it can't solve the problem.
Hi @Anonymous
Did you completely remove the folder like I mentioned to do in that step?
If that doesn't work you could uninstall the desktop app and that should remove it or you could then reinstall the Desktop app and then delete that folder again.
You just need to make sure you 100% remove the folder and files related to the ACWebBrowser.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
