What is AcWebBrowser.exe and why does it run all the time?
1. Attachment is the recommended resolution to your case:
The AcWebBrowser.exe" is an application that gets launched with running an Autodesk program,
that allows these programs to browse out to the web for common data.
Some common functions that utilize this application are the "Geolocation" tools, "Help" dialogs etc.
If it do cause software performance, you could disable it manually.
Thanks for contacting with Autodesk Technical Support.
I wasnt satisfied with this answer , second reply from Autodesk;
Answer;
2. Thank you for choosing Autodesk Support. Here is the recommended resolution to your case:
From technical document, ACWebBrowser.exe is the core app about Autodesk Desktop App.
So any functions using Autodesk Desktop will use ACWebBrowser.exe.
Autodesk Desktop App is the platform for Autodesk Customer contact Autodesk via network.
You could download software, update, submit case to Autodesk and so on.
These function you could access website (e.g. manage.autodesk.com or knowledge.autodesk.com) directly.
Please see
Autodesk Desktop App: Exploring the Features and Benefits of AutoCAD about more information.
In this situation, you could uninstall Autodesk Desktop App from your computer,
there ACWebBrowser.exe will not affect performance of software. This will not affect Autodesk Product using.
Go to Windows Control Panel to uninstall Autodesk Desktop App.
