Im using maya's xgen and I made a clumping modifier and wanted to create a mask to stop certain areas from clumping and the 3d paint tool wasn't work and i believe it is because i mapped two parts of the model in separate UDIM tiles, is there any way to get 3D paint brush to work with UDIM for simplicity?
Hi @Bryant4863
Masks in Xgen are ptex based and Maya only uses one UV tile to bake the color into ptex.
I believe if you wanted to bake out a map using UDIM you would need to use a different program like Mudbox/3DCoat etc.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Bryant4863
I'm just checking in again to see if you need more help with this. Did the suggestion I provided on Friday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
