3Dpainting with UDIM
Bryant4863
Bryant4863
Im using maya's xgen and I made a clumping modifier and wanted to create a mask to stop certain areas from clumping and the 3d paint tool wasn't work and i believe it is because i mapped two parts of the model in separate UDIM tiles, is there any way to get 3D paint brush to work with UDIM for simplicity?
sean.heasley
Hi @Bryant4863
Masks in Xgen are ptex based and Maya only uses one UV tile to bake the color into ptex.
I believe if you wanted to bake out a map using UDIM you would need to use a different program like Mudbox/3DCoat etc.
sean.heasley
Hi @Bryant4863
I'm just checking in again to see if you need more help with this. Did the suggestion I provided on Friday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
