After importing a model from Maya 2018 is looks fine, however, the geometry becomes scrambled completely upon switching from smoothed mesh (key 3) to smooth zero (key 1). Will include pictures. The geometry still appears to be fine in memory, as I can switch back and forth from smooth to simply poly, and the smoothed version still looks correct. But the simply poly view remains totally scrambled in the viewport and unuseable.
Exporting and then re-importing the model (through OBJ or FBX) seems to solve the problem, but loses all my model creases, and then becomes scrambled again later.
HELP! Thanks
smooth 0 - mesh correct
smooth 1 mesh correct
back to smooth 0 - mesh is scrambled
Hi!
This looks like a problem with your GPU / driver.
Please upload a scene-file to enable other users to check the mesh and provide details about your GPU / driver version and Render Engine settings in Maya.
With further testing, the problem is definitely related to instancing and scaling negative X -- i.e. mirroring. It's something I use often for symetrcial modeling. While I can work around it, it's a bit of a pain and I'd like to know what's causing the problem. Maya 2018 doesn't have the problem.
Even a simple mesh instanced and mirrored is causing the problem, scrambling on switching back from smooth to unsmoothed view. I think the geometry is actually fine, but it's some GPU call that is bugged.
I'm using 417.35 drivers on my nvidia 10xx series cards, which are the latest certified.
