Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
How to achieve this? (Thousands of objects)
2 REPLIES 2
Toquitaa
215 Views, 2 Replies
Hi there!
I need help on the following:
- I need to make thousands of objects (imagine crickets) flying in a completely random fashion;
- Then these objects will slowly form into a logo;
Where could I start researching this? I'm starting with nParticles but I can't really use an object as particles (like if I actually want to model a cricket and use it as an nParticle and emit it thousands of times).
Thank you
2 REPLIES 2
Kahylan
in reply to: Toquitaa
Hi!
You can use Mash to bind geometry to your particles.
Here is a Tutorial on this. It's a bit older so somethings might have changed in the meantime, but it should give you a good starting point to what you are looking for.
https://www.youtube.com/watch?v=LtXwqxGDd74&t=165s
I hope it helps!
dinofiguera
some very nice effects can be done directly in Mash,
I have created an effortless effect that took me less than 2 minutes to set up.
It is very simple but can be a starting point to developing a more detailed result...
Technology Administrators
