I am using the rule from the forum. Thanks to the forum.
It is fine, but I don't get the TEXT SIZE updated to look similar to the text size of the reference label.
I look forward to receiving help. Thanks.
Sub Main ' get app obj oApp = ThisApplication 'get document obj Dim oDoc As Document oDoc = ThisApplication.ActiveDocument ' define where to start if selection was not a view label obj Reselect1: Dim oObj1 As Object ' prompt user to select a view label to copy oObj1 = oApp.CommandManager.Pick(kAllEntitiesFilter, "Select View Label to Copy") ' if user presses escape, then oObj1 gets set to Nothing ' test if the user pressed ESC If oObj1 Is Nothing Then Exit Sub ' if the selected obj is NOT a view label then goto Reselect1: ElseIf Not TypeOf oObj1 Is DrawingViewLabel Then GoTo Reselect1 End If Dim oView1 As DrawingViewLabel oView1 = oObj1 MessageBox.Show("OK. You selected a view label! " & oObj1.Text, "Title") Dim oLabel_Ref As DrawingViewLabel oLabel_Ref = oObj1 ' get formatted text from label Dim oFormattedText_RefLabel As String oFormattedText_RefLabel = oLabel_Ref.FormattedText ' define where to start if second selection was not a drawing view obj Reselect2: Dim oObj2 As Object oObj2 = oApp.CommandManager.Pick(kAllEntitiesFilter, "Select the Destination View to Copy to") ' if user presses escape, then oObj gets set to Nothing ' test if user pressed ESC If oObj2 Is Nothing Then Exit Sub ' if user selects another sheet, go to that sheet then goto Reselect2: ElseIf TypeOf oObj2 Is Sheet Then oObj2.Activate GoTo Reselect2 ' if code gets here then selected obj is not a sheet object. ' If selected object is NOT a view label then goto Reselect2: ElseIf Not TypeOf oObj2 Is DrawingView Then 'GoTo Reselect2 'Else End If Dim oView2 As DrawingViewLabel oView2 = oObj2 MessageBox.Show("OK. You selected the Destination view label! " & oObj2.Text, "Title") Dim oLabel_Destination As DrawingViewLabel oLabel_Destination = oObj2 ' get formatted text from label Dim oFormattedText_Destination As String oFormattedText_Destination = oLabel_Destination.FormattedText '' turn visibility of label on 'oView2.ShowLabel = True Dim oView As DrawingView oLabel_Destination.FormattedText = oFormattedText_RefLabel 'oFormattedText_RefLabel 'End If InventorVb.DocumentUpdate(False) End Sub
Solved by bradeneuropeArthur. Go to Solution.
You should better update the styles.
Than updated the drawing directly and automatically.
Regards
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
