Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
BOM Export to excel StructuredViewFirstLevelOnly customization
1 REPLY 1
akaluri
307 Views, 1 Reply
I have a main assembly that have sub-assemblies (Level 1). The sub-assemblies in turn have parts+sub-assemblies (Level-2). I want the exported excel BOM to have parts+subassemblies (Level-2). I am using the following code to export to excel. But the problem is, when 'oBOM.StructuredViewFirstLevelOnly = False', all the part that are under sub-assembly 2 are also exported. I thought of traversing through the main assembly and not exporting the subassemblies (Level-2), but the BOMExport API erases the previous data when it is called each time.
So is there anyway we can set 'oBOM.StructuredViewFirstLevelOnly =' False only till first level and then true at the second level? Thank you.
Dim oDoc As AssemblyDocument
     oDoc = ThisApplication.ActiveDocument
    '  a reference to the BOM
    Dim oBOM As BOM
     oBOM = oDoc.ComponentDefinition.BOM
    '  the structured view to 'all levels'
    oBOM.StructuredViewFirstLevelOnly = False  '(Want this to be false for level 1 and true for level 2)
    ' Make sure that the structured view is enabled.
    oBOM.StructuredViewEnabled = True
    '  a reference to the "Structured" BOMView
    Dim oStructuredBOMView As BOMView
     oStructuredBOMView = oBOM.BOMViews.Item("Structured")
    ' Export the BOM view to an Excel file
    oStructuredBOMView.Export ("C:\........", kMicrosoftExcelFormat)
1 REPLY 1
JelteDeJong
in reply to: akaluri
you can travel through the assembly and give the exported excel a different name and the later combine the excel files. Here an example iLogic rule that will create a excel file for the level-1 assembly and different files for the level-2 assemblies.
Sub Main()
    Dim doc As AssemblyDocument = ThisDoc.Document
    'export level-1
    exportBom(doc, True)
    'find all level-2 documents
    For Each occ As ComponentOccurrence In doc.ComponentDefinition.Occurrences
        'next line will fail if an occurence is not an Document. (like a viritual part)
        Dim occDoc As Document = occ.ReferencedDocumentDescriptor.ReferencedDocument
        'export level-2 assemblys
        If (occDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject) Then
            exportBom(occDoc, False)
    Next
End Sub
Public Sub exportBom(doc As AssemblyDocument, StructuredViewFirstLevelOnly As Boolean)
    Dim oBOM As BOM = doc.ComponentDefinition.BOM
    oBOM.StructuredViewFirstLevelOnly = StructuredViewFirstLevelOnly
    Dim oStructuredBOMView As BOMView = oBOM.BOMViews.Item("Structured")
    Dim excelFileName As String = doc.FullFileName.Replace(".iam", ".xls")
    oStructuredBOMView.Export(excelFileName, FileFormatEnum.kMicrosoftExcelFormat)
	MsgBox("Create/exported file: " & excelFileName)
End Sub
(i did not include code to combine the excel files)
Jelte de Jong
Blog: hjalte.nl - github.com
Technology Administrators
