I have a main assembly that have sub-assemblies (Level 1). The sub-assemblies in turn have parts+sub-assemblies (Level-2). I want the exported excel BOM to have parts+subassemblies (Level-2). I am using the following code to export to excel. But the problem is, when 'oBOM.StructuredViewFirstLevelOnly = False', all the part that are under sub-assembly 2 are also exported. I thought of traversing through the main assembly and not exporting the subassemblies (Level-2), but the BOMExport API erases the previous data when it is called each time.
So is there anyway we can set 'oBOM.StructuredViewFirstLevelOnly =' False only till first level and then true at the second level? Thank you.
Dim oDoc As AssemblyDocument oDoc = ThisApplication.ActiveDocument ' a reference to the BOM Dim oBOM As BOM oBOM = oDoc.ComponentDefinition.BOM ' the structured view to 'all levels' oBOM.StructuredViewFirstLevelOnly = False '(Want this to be false for level 1 and true for level 2) ' Make sure that the structured view is enabled. oBOM.StructuredViewEnabled = True ' a reference to the "Structured" BOMView Dim oStructuredBOMView As BOMView oStructuredBOMView = oBOM.BOMViews.Item("Structured") ' Export the BOM view to an Excel file oStructuredBOMView.Export ("C:\........", kMicrosoftExcelFormat)
you can travel through the assembly and give the exported excel a different name and the later combine the excel files. Here an example iLogic rule that will create a excel file for the level-1 assembly and different files for the level-2 assemblies.
Sub Main() Dim doc As AssemblyDocument = ThisDoc.Document 'export level-1 exportBom(doc, True) 'find all level-2 documents For Each occ As ComponentOccurrence In doc.ComponentDefinition.Occurrences 'next line will fail if an occurence is not an Document. (like a viritual part) Dim occDoc As Document = occ.ReferencedDocumentDescriptor.ReferencedDocument 'export level-2 assemblys If (occDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject) Then exportBom(occDoc, False) End If Next End Sub Public Sub exportBom(doc As AssemblyDocument, StructuredViewFirstLevelOnly As Boolean) ' a reference to the BOM Dim oBOM As BOM = doc.ComponentDefinition.BOM ' the structured view to 'all levels' oBOM.StructuredViewFirstLevelOnly = StructuredViewFirstLevelOnly ' Make sure that the structured view is enabled. oBOM.StructuredViewEnabled = True ' a reference to the "Structured" BOMView Dim oStructuredBOMView As BOMView = oBOM.BOMViews.Item("Structured") Dim excelFileName As String = doc.FullFileName.Replace(".iam", ".xls") ' Export the BOM view to an Excel file oStructuredBOMView.Export(excelFileName, FileFormatEnum.kMicrosoftExcelFormat) MsgBox("Create/exported file: " & excelFileName) End Sub
(i did not include code to combine the excel files)
Jelte de Jong
Blog: hjalte.nl - github.com
