I have a form that instantiated on a button click on custom ribbon for a custom add-in. I'm noticing some behavior that is odd and after a lot of research I think it's Inventor application causing this behavior.
Controls
3 text boxes, tab index is 1, 2, 3 where tabstop = True for all three. All other label controls have a greater than 3 tab index.
Form
KeyPreview Property = True
What occurs is when a tab happens after the form loads the windows chime sounds like it is not allowed.
Has anyone had this situation where tab was not allowed on a windows form within a custom addin? If so what did you do?
Thanks!
Tiffany Hayden
Solved by bradeneuropeArthur. Go to Solution.
Do you use show or showdialog?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Tiffany Hayden
Could you try showdialog, if that makes difference?
Arthur Knoors
Tiffany Hayden
@bradeneuropeArthur Changing it from show to showdialog worked! Thanks so much!
Tiffany Hayden
Sometimes the solution is closer than is thought.
Let me know if you have any other or programming related issues.
Arthur Knoors
Yes I searched high and low! That's why I love the forums. So many people that have so much experience in one place. I'm so glad we have this community. 😊😊
Tiffany Hayden
