I have problem with my StatusBarTex when the dark mode is on. The text appear in black color which is almost not readable. It is only when I'm using it by my macros with InteractionEvents.StatusBarText property. All other standard messages of Inventor are in white color. How I can fix it?
This has already been reported as a bug by @JelteDeJong if I am correct.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
i just checked in Inventor 2022. Its not solved:
Jelte de Jong
Blog: hjalte.nl - github.com
Can someone please add this to the JDI list? Or give it to an intern to fix... it should be an easy enough thing to solve.
Just for giggles, I tried this rule in Inventor 2023
ThisApplication.StatusBarText = "is it solved in Inventor 2023?"
Jelte de Jong
