StatusBarText issue when dark mode is on
4 REPLIES 4
l.orzechowski
394 Views, 4 Replies
I have problem with my StatusBarTex when the dark mode is on. The text appear in black color which is almost not readable. It is only when I'm using it by my macros with InteractionEvents.StatusBarText property. All other standard messages of Inventor are in white color. How I can fix it?
Labels (2)
4 REPLIES 4
This has already been reported as a bug by @JelteDeJong if I am correct.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
i just checked in Inventor 2022. Its not solved:
Jelte de Jong
Blog: hjalte.nl - github.com
Can someone please add this to the JDI list?  Or give it to an intern to fix...  it should be an easy enough thing to solve.
JelteDeJong
in reply to: CamperUnhappy
Just for giggles, I tried this rule in Inventor 2023
ThisApplication.StatusBarText = "is it solved in Inventor 2023?"
Jelte de Jong
