Search for common text in multiple ilogic rules?
D0UGLAS
D0UGLAS
Does anyone have any better ideas or knowledge of how to search for and locate identical text strings, features in several ilogic rules at once?
1) I have a model with 30+ rules, I have merged them together, but they were unmanageable.
2) Another way I have found is to search and replace all instances in all of the rules with the same or a corrupt text. The same text helps me identify how many occurrences there are, the corrupt text can help me find the rule, but this does not always work, and not finding the now corrupted text leads to problems down the line.
3) Also copying all of the rules into a text editor made them accessible but again this is impractical.
example
I am looking for something like this it doesn't have to be within the ilogic environment I just need a quick way to find features for editing...
Input
search 30 rules where is text  "rhubarb n custard"
8 occurrences found
4 in rule 1,
1 in rule 9,
2 in rule 16,
1 in rule 29
bradeneuropeArthur
This may be not the solution, but is more as a "Tip".
Start programming your own add in.
The story above is one of the BIG disadvantages of build in code like VBA or I-logic.
For sure if you have a model with 30 + rules, an add in is the better way of programming!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
D0UGLAS
Ah… I wish there was a macro record feature, that could set me off in the right direction..
Thanks for your help..
bradeneuropeArthur
@D0UGLAS
You have already programmed a lot with I-logic!
The step to vb.net and add ins isn't the huge/far away!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
chandra.shekar.g
Autodesk Support
Autodesk Support
@D0UGLAS,
In the below blog link, an Inventor addin is used to play with iLogic rules.
https://beinginventive.typepad.com/being-inventive/2012/02/injecting-ilogic-code-and-ilogic-event-tr...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
