C360_OnPublishDrawing not recognizing If Statement
kyle72833
kyle72833
I am using the Rule “C360_OnPublishDrawing” to make a couple changes to a drawing based on user selections and I am having a problem with it when I upload to C360.  One section of the code in particular seems to not be working:
If Parameter("LDDSMaster.iam.EOD")=False
        ActiveSheet.View("VIEW1").View.BreakOperations(1).Delete
What I want to happen is, if the EOD variable is False, I want all the drawing breaks to be deleted.  This rule works perfectly in Inventor 2019 but when I upload it to C360 something goes wrong and it deletes all breaks no matter what the EOD variable is.
I'm successfully using the rest of the code in the rule to cleaning up dimensions, but the section to delete the drawing breaks is not working correctly.
chandra.shekar.g
Autodesk Support
Autodesk Support
@kyle72833,
Can you please provide non confidential source code and model data to test the behavior?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
KKizildemir
Hi @kyle72833
Is 'LDDSMaster.iam' file your master assembly file? If it is, please insert the code into your 'C360_OnPublishDrawing' Rule.
Dim oDwgDoc As Inventor.DrawingDocument = ThisDoc.Document
Dim oAsmDoc As Inventor.AssemblyDocument = oDwgDoc.ReferencedDocuments.Item(1)
For Each oParam As Inventor.Parameter In oAsmDoc.ComponentDefinition.Parameters.UserParameters
	If oParam.Name = "EOD" Then
		If oParam.Value = False Then
		Exit For
Next
Regards
Signature
website
emailskypelinkedinyoutubeemail
kyle72833
This worked perfectly.  Thank you for your help.
@KKizildemir wrote:
Hi @kyle72833
		Exit For
Next
Regards
KKizildemir
You're welcome. Don't forget to subscribe Codeo Youtube Channel to get interesting ideas about C360!
Signature
website
