VBA Macro translate
VBA Macro translate
VBA Macro translate
I would want to translate this code from Ilogic to VBA macro. Is there a kind soul who would help me with this code??
Sub Main()
oDoc = ThisApplication.ActiveDocument
Dim oSelectSet As SelectSet
oSelectSet = oDoc.SelectSet
oSelectSet.Clear
osketch=ThisApplication.ActiveEditObject
If osketch.type=83924736 Then
    If osketch.sketchblocks.count=0 Then
        Exit Sub
    oSelectSet.select(osketch.sketchblocks.Item(SharedVariable("i")))
    SharedVariable("i")=SharedVariable("i")+1
ElseIf osketch.type=84006912 Then
    If osketch.ChildBlocks.count=0 Then
        Exit Sub
    If SharedVariable("i")>osketch.ChildBlocks.count Then
    SharedVariable("i")=1
    oSelectSet.select(osketch.ChildBlocks.Item(SharedVariable("i")))
End Sub
bradeneuropeArthur
Sub Main()
dim oDoc as PartDocument
set oDoc = ThisApplication.ActiveDocument
Set oSelectSet = oDoc.SelectSet
oSelectSet.Clear
osketch = ThisApplication.ActiveEditObject
If osketch.Type = 83924736 Then
    If osketch.SketchBlocks.Count = 0 Then
        Exit Sub
    oSelectSet.Select (osketch.SketchBlocks.Item(SharedVariable("i")))
    SharedVariable("i") = SharedVariable("i") + 1
ElseIf osketch.Type = 84006912 Then
    If osketch.ChildBlocks.Count = 0 Then
        Exit Sub
    If SharedVariable("i") > osketch.ChildBlocks.Count Then
    SharedVariable("i") = 1
    oSelectSet.Select (osketch.ChildBlocks.Item(SharedVariable("i")))
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
