Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Rule or VBA Macro to change a dimension style for radii
4 REPLIES 4
torben_schroederXDK86
178 Views, 4 Replies
Hey.
I have tried my hand at ilogic and VBA a bit. After asking Chat GPT alot and googling alot i came to the conclusion to ask the experts here, as i was not able to find a solution.
what i want to achieve with this code is to change the dimension for radii from "horizontal" to "aligned". Not more. But i can not seem to get it done.
i only have a code generated from ChatGPT which doesnt work.
can someone help me out here?
4 REPLIES 4
Please follow the guidelines described HERE and DON'T post code from ChatGPT with syntax errors.
For example object RadiusTextOrientation doesn't exist.
Okay, my bad. I just wanted to give some kind of "base" trhat can be worked on. I can delete it, if thats whats needed.
I just dont know what exists and what doesnt. Is there some kind of API Database for Inventor that i can look at?
Here is on-line version of API help.
Or off-line version is available from Inventor Help menu
try this
 'set active document as drawing document
	Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
	'get the active dim style
	Dim oDStyle As DimensionStyle = oDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.LinearDimensionStyle
	oDStyle.RadialTextOrientation = DimensionTextOrientationEnum.kInlineAlignedDimensionText
! For administrative reasons, please mark a "Solution as solved" when the issue is solved !
Technology Administrators
