Hey.
I have tried my hand at ilogic and VBA a bit. After asking Chat GPT alot and googling alot i came to the conclusion to ask the experts here, as i was not able to find a solution.
what i want to achieve with this code is to change the dimension for radii from "horizontal" to "aligned". Not more. But i can not seem to get it done.
i only have a code generated from ChatGPT which doesnt work.
can someone help me out here?
Solved by nstevelmans. Go to Solution.
Okay, my bad. I just wanted to give some kind of "base" trhat can be worked on. I can delete it, if thats whats needed.
I just dont know what exists and what doesnt. Is there some kind of API Database for Inventor that i can look at?
try this
'set active document as drawing document Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument 'get the active dim style Dim oDStyle As DimensionStyle = oDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.LinearDimensionStyle oDStyle.RadialTextOrientation = DimensionTextOrientationEnum.kInlineAlignedDimensionText
