Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Primary Tolerance Change Ilogic
2 REPLIES 2
kacper_sikorskiD42JA
143 Views, 2 Replies
How can i change Primary Tolerance using Ilogic?
I know how to change Primary Unit but i can't find the other one.
Thank you 😄
Labels (3)
2 REPLIES 2
For specific dimension you can use its Tolerance property and appropriate methods
Dim dimension As DrawingDimension = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Pick dimension")
dimension.Tolerance.SetToSymmetric(0.01)
There is also this property:
DrawingDimension.TolerancePrecision
Wesley Crihfield
(Not an Autodesk Employee)
Technology Administrators
