Primary Tolerance Change Ilogic
kacper_sikorskiD42JA
How can i change Primary Tolerance using Ilogic?
I know how to change Primary Unit but i can't find the other one.
Thank you :grinning_face_with_smiling_eyes:
Michael.Navara
For specific dimension you can use its Tolerance property and appropriate methods
Dim dimension As DrawingDimension = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Pick dimension")
dimension.Tolerance.SetToSymmetric(0.01)
WCrihfield
There is also this property:
DrawingDimension.TolerancePrecision
Wesley Crihfield
(Not an Autodesk Employee)
