Round off to no decimals without comma
sso_enerdry
sso_enerdry
I have a short Ilogic, that rounds of my mass on my parts/assemblies as follows:
If iProperties.Mass<0.1 Then
iProperties.Value("custom", "Rounded_Mass") = Round(iProperties.Mass, 3)
ElseIf iProperties.Mass<1 Then
iProperties.Value("custom", "Rounded_Mass") = Round(iProperties.Mass, 2)
ElseIf iProperties.Mass<10 Then
iProperties.Value("custom", "Rounded_Mass") = Round(iProperties.Mass, 1)
Else If iProperties.Mass>10 Then
iProperties.Value("custom", "Rounded_Mass") = Round(iProperties.Mass, 0)
InventorVb.DocumentUpdate()
End If
The last Else If - when the mass is over 10 kg. I want it to show the mass without decimals.
This works, but it keeps writing e.g. "165," instead of "165"
How do I remove the comma?
Thanks in advance.
blandb
I copied your code into a part in 2019 and I dont get the comma.
Autodesk Certified Professional
marcin_otręba
try cstr(Round(iProperties.Mass, 0)).Replace(",", "")
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
bradeneuropeArthur
@sso_enerdry
What version of inventor are you working with?
did you choose the Rounded_Mass as number or as text?
for me the code works fine with as number...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
sso_enerdry
Hi Marcin
Your solution seems to work.
I also tried this, for the last line:
Properties.Value("custom", "Rounded_Mass") = Int(iProperties.Mass)
Which seems to solve the problem as well.
Soeren
sso_enerdry
hi Bradeneurope
I'm running Inventor 2018.
I've solved the problem by turning the rounded value into an integer.
It is a little funny though, that I couldn't get my first try to work
but thanks anyway
br
Soeren
