Hello all,
Inventor 2025 is based on .NET8 - for this reason all Add-Ins must be ported to .NET8, as announced on the beta.autodesk.com in Inventor2025 API help section.
How is the best practice to achieve this?
Thank you in advance!
BR
I found that less steps are needed compared to the Pdf file instruction.
Most things seem to be done with the upgrade process in visual studio...
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
