Porting from .NET framework to .NET8
20 REPLIES 20
Message 1 of 21
h.schkorwaga
1229 Views, 20 Replies
Hello all,
Inventor 2025 is based on .NET8 - for this reason all Add-Ins must be ported to .NET8, as announced on the beta.autodesk.com in Inventor2025 API help section.
How is the best practice to achieve this?
Thank you in advance!
BR
20 REPLIES 20
Message 21 of 21
I found that less steps are needed compared to the Pdf file instruction.
Most things seem to be done with the upgrade process in visual studio...
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Technology Administrators
