As per title, in the 2019 version, my custom forms are listed under the tab but in 2020, it's empty (see pic below):
I can manually add iLogic rules, but the how do I do it for forms?
The form xml files are listed in the relevant containing folder.
Solved by MjDeck. Go to Solution.
Check if the file path's are correct!
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
The default containing folder is under Design Data. It is different for 2019 and 2020.
Have you copied the files from the 2019 folder to the 2020 folder? If so, please try right-clicking in the Global Forms pane and choose the Refresh command from the context menu.
Thanks for the replies.
The folder location was correct & the xml files had been copied across.
The "refresh" worked, but oddly, I had added some icons for the forms & it wasn't until I'd copied a file named "iLogicBrowserUiFormSpecification.xml" that the icons were visible (even though the icon data was in the individual form xml files.
What's worse, I can't remember how I added the icons, so there's also that.
Anyway, it's sorted for another year.
