Does a 2020 Icon Guidelines exist? Or something similar.
If you go to %Public%Documents\Autodesk\Inventor 2020\SDK\ and install Developertools you get the old guidelines in %Public%Documents\Autodesk\Inventor 2020\SDK\DeveloperTools\Docs\Guidelines.
Have you written something new about the Inventor 2020 Icons style?
Thanks.
What inventor version are you using?
The older version is still useable...
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
I thought was pretty clear I'm using Inventor 2020 🙂
I would like to update my custom icons according with the new style. And that manual would be very useful if it was updated.
