Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
External rule - not reading parameter from sheetmetal
1 REPLY 1
Charlies_3D_T
192 Views, 1 Reply
For some reason when i transfer a rule to an external rule it's not working.
It's doesn't read the parameter Thickness. Someone any idea what i'm forgetting?
If Parameter("Thickness") = "1.0" Or Parameter("Thickness") = "1.5" Or Parameter("Thickness") = "2" Or Parameter("Thickness") = "3" Or Parameter("Thickness") = "4" Then
	'iProperties.Value("Custom", "BendRadius_Ilogic") = 1
	Parameter("BendRadius_Ilogic") = 1
    MessageBox.Show(Parameter("BendRadius_Ilogic"), "Title")
ElseIf Parameter("Thickness") = "5" Or Parameter("Thickness") = "6.0" Or Parameter("Thickness") = "8" Or Parameter("Thickness") = "10" Or Parameter("Thickness") = "12" Or Parameter("Thickness") = "15" Or Parameter("Thickness") = "20" Then
    'iProperties.Value("Custom", "BendRadius_Ilogic") = 4
	Parameter("BendRadius_Ilogic") = 4
Else
	MessageBox.Show("Error in thickness rule", "Title")
1 REPLY 1
How do you call/run your external rule?
For me it works when I use this in an external rule!
iLogicVb.RunExternalRule("xyz")
Regards
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Technology Administrators
