Link level of detail via api
jan.pomplun
jan.pomplun
Is it possible to use the 'Link Levels of Detail' command via the API ?
I can activate the command by using the CommandManager
oContDef = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyBonusTools_LinkLODsCmd")
oContDef.Execute
But the command then requires a UI selection. Can this be automated via API or is there another way to link the details?
This question was asked some time ago, but the workaround does not work for me.
Jan
MechMachineMan
Sure.
Just use the selection set to PRE-select the command you want to use.
Also, google brings up a pretty neat blog....
http://lmgtfy.com/?q=Inventor+%2B+API+%2B+control+definition
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
bradeneuropeArthur
I will take a look, I have this coding prepared earlier.
But I need to copy it.
You will here ASAP
Regards
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Could you please remind me on Monday to do this.
I forgot. Or send me a private message.
Thank you
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Type a product name
