Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Keyboard TAB key functionality in iProperty.
4 REPLIES 4
aurel_e
202 Views, 4 Replies
In my drawing template we have got iProperties: "Works Order No" and "Customer".
I need to insert in the drawing a QR code. Scanning that would fill 2 fields in a form. The qr code need to concatenate a combined iProperty that would look like =<Works Order No> & Tab & <Customer>.
Any idea how to achieve that? Or if you know any QR code addin to combine iproperties like that?
Thanks.
4 REPLIES 4
Hi this code seems to work in the value field but the text does not show the tab.
Sub IpropertyWithTab()
Dim odoc As PartDocument
Set odoc = ThisApplication.ActiveDocument
odoc.PropertySets.Item("User Defined Properties").Item("test").Value = "test" & vbTab & "test"
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Michael.Navara
in reply to: aurel_e
For conversion iProperty value to QR Code you can use Be.Smart Tools4Inventor
Content of the iProperty expression can be created using external program like notepad. Write text for expression (including 'tab') in notepad and Copy+Paste put them to iProperty expression.
TAB HAS 8 SPACES
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Michael.Navara
You can also update the solution provided by @bradeneuropeArthur with the following:
Use Tab char in iProperty instead of whitespaces, because with Tab the texts become aligned.
You can create custom iProperty named Tab using simple code below
iProperties.Value("Custom", "Tab") = vbTab
Technology Administrators
