So I can't figure why the command is working or assembly iAssy but not for the part iPart. Below is the chunk of code to run them. I've attached example files I was using.
Dim Path As String = "C:\TEST\ExportTest"
Dim ExportFile As String = Path & ".xls"
Logger.Info("ExportFile " & ExportFile)
Dim oDoc As Document = ThisDoc.Document
If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
Logger.Info("Assy FileType")
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
If oAsmDoc.ComponentDefinition.IsiAssemblyFactory = True Then
Logger.Info("Assy iAssemblyFactory Found")
Dim oiAssyFactory As iAssemblyFactory = oAsmDoc.ComponentDefinition.iAssemblyFactory
oiAssyFactory.Export(ExportFile, FileFormatEnum.kMicrosoftExcelFormat)
End If
End If
If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
Logger.Info("Part FileType")
Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
Logger.Info("oPartDoc")
If oPartDoc.ComponentDefinition.IsiPartFactory = True Then
Logger.Info("Part iPartFactory Found")
Dim oiPartFactory As iPartFactory = oPartDoc.ComponentDefinition.iPartFactory
oiPartFactory.Export(ExportFile, FileFormatEnum.kMicrosoftExcelFormat)
End If
End If
Solved by bradeneuropeArthur. Go to Solution.
Dim ExportFile As String = Path & ".xlsx"
End If
End If
End If
End If
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
use "xlsx" instead of "xls"
Arthur Knoors
so that works.... but WTF...
why is it .xls for Assemblies (and .xlsx doesn't work) and .xlsx for Parts (And .xls doesn't work)?
Regardless the why... it's working; I'll take it. 🙂
That is indeed strange!
@johnsonshiue Do you have any idea why that is the case!
Arthur Knoors
