Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic to Create Sketch
11 REPLIES 11
Message 1 of 12
felix.cortes5K3Y2
4053 Views, 11 Replies
Hi Forum,
I am trying to write a code to create a sketch. Let's say you created a new part and a sketch doesn't exist. How can I write the code so that a new sketch, "Sketch1," gets created on a plane, "YZ Plane"? Is there a way to create a text box using iLogic?
Best regards,
Felix Cortes
11 REPLIES 11
Message 2 of 12
Hi, try this code, I think this segment could serve you, greetings!
Dim oDoc As PartDocument = ThisDoc.Document
' Set a reference to the component definition.
Dim oCD As PartComponentDefinition
oCD = oDoc.ComponentDefinition
'Select Plane
'Dim oPlaneYZ As WorkPlane = oCD.WorkPlanes.Item(1)
'Dim oPlaneXZ As WorkPlane = oCD.WorkPlanes.Item(2)
Dim oPlaneXY As WorkPlane = oCD.WorkPlanes.Item(3)
' Create a new sketch.
Dim oSketch As Sketch
oSketch = oCD.Sketches.Add(oPlaneXY)
oSketch.Name = "My_Sketch"
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 12
Public Sub Main()
    ' Get the active part document.
    Dim partDoc As PartDocument
   partDoc = ThisApplication.ActiveDocument
    Dim partDef As PartComponentDefinition
   partDef = partDoc.ComponentDefinition
    Dim sketch As PlanarSketch
   sketch = partDef.Sketches.Add(partDef.WorkPlanes.Item(3))
    Dim tg As TransientGeometry
   tg = ThisApplication.TransientGeometry
    ThisApplication.ActiveView.Fit
End Sub
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Message 4 of 12
@Sergio.D.Suárez
That was close!
Arthur Knoors
Message 5 of 12
Hey Sergio,
The code works great on parts, however, when I try it on the flat pattern of a sheet metal part, it doesn't run it. How would the code change for the flat pattern? Also, is there a way to create a Text onto the newly created sketch using iLogic only?
Best regards,
Felix Cortes
Message 6 of 12
Hi, if what you are looking for is to create a sketch in the flatt pattern, I think that a simple ilogic code like the following could be useful.
Dim oPartDoc As PartDocument = ThisDoc.Document
'verify document type is sheet metal
If oPartDoc.ComponentDefinition.Type <> 150995200 Then
	MessageBox.Show("File is not a sheet metal part.", "iLogic")
	Exit Sub
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
' Check to make sure a flat pattern is open.
If Not TypeOf ThisApplication.ActiveEditObject Is FlatPattern Then
	Try
		If oCompDef.HasFlatPattern = False Then
			oCompDef.Unfold
		'Else
			'oCompDef.FlatPattern.Edit
	Catch
		MessageBox.Show("Error editting the flat pattern.", "iLogic")
	End Try
'  a reference to the active flat pattern.
Dim oFlatPattern As FlatPattern = oCompDef.FlatPattern
Dim oFace As Face = oFlatPattern.TopFace ' = oFlatPattern.BottomFace
Dim oSketch As PlanarSketch
oSketch = oFlatPattern.Sketches.Add(oFace)
 I hope the code is useful for you. regards
Mechanical Designer
Message 7 of 12
Awesome!
Message 8 of 12
Excuse me, I just saw that you wanted to add a text, I hope the final lines can be used to give you an idea, maybe by modifying them for a later use. Regards!
'  a reference to the active document.
oPartDoc = ThisApplication.ActiveDocument
	Exit Sub
	Try
			oCompDef.Unfold
		'Else
	Catch
	End Try
Dim oFlatPattern As FlatPattern = oCompDef.FlatPattern' ThisApplication.ActiveEditObject
oSketch = oFlatPattern.Sketches.Add(oFace)', False)
Dim sText As String = "Here is the last and final line of text."
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
oTextBox  = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(oSketch.OriginPointGeometry.X, _
                                oSketch.OriginPointGeometry.Y), sText)
Mechanical Designer
Message 9 of 12
Thanks Sergio!
Message 10 of 12
Hi Sergio,
I am attempting to rotate the text to 90 degrees. I've tried the following code but it doesn't seem to work.
	Exit Sub
	Try
			oCompDef.Unfold
		'Else
	Catch
	End Try
'oTextBox  = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(oSketch.OriginPointGeometry.X, _
'                                oSketch.OriginPointGeometry.Y), sText)
oTextBox = oSketch.TextBoxes.AddByRectangle(oTG.CreatePoint2d(oSketch.OriginPointGeometry.X, _
                                oSketch.OriginPointGeometry.Y), oTG.CreatePoint2d(0,2), sText)
'oTextBox  = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(oSketch.OriginPointGeometry.Y, _
'                                oSketch.OriginPointGeometry.X), sText)
oTextBox.RotateSketchObjects(oSketch,oTG.CreatePoint2d(oSketch.OriginPointGeometry.X, oSketch.OriginPointGeometry.Y), 90)
Best regards,
Felix Cortes
Message 11 of 12
Hi Felix !, Try this code, I hope you can be useful! I found the access in the API. Best regards!
	Exit Sub
	Try
			oCompDef.Unfold
		'Else
	Catch
	End Try
  ' supports only 0, pi/2, pi, 1.5pi
 oTextBox.Rotation = PI/2     'Math.Atan(1) * 2
Mechanical Designer
Message 12 of 12
I was close! Thanks Sergio
Technology Administrators
