Hi Forum,
I am trying to write a code to create a sketch. Let's say you created a new part and a sketch doesn't exist. How can I write the code so that a new sketch, "Sketch1," gets created on a plane, "YZ Plane"? Is there a way to create a text box using iLogic?
Best regards,
Felix Cortes
Solved by Sergio.D.Suárez. Go to Solution.
Hi, try this code, I think this segment could serve you, greetings!
Dim oDoc As PartDocument = ThisDoc.Document ' Set a reference to the component definition. Dim oCD As PartComponentDefinition oCD = oDoc.ComponentDefinition 'Select Plane 'Dim oPlaneYZ As WorkPlane = oCD.WorkPlanes.Item(1) 'Dim oPlaneXZ As WorkPlane = oCD.WorkPlanes.Item(2) Dim oPlaneXY As WorkPlane = oCD.WorkPlanes.Item(3) ' Create a new sketch. Dim oSketch As Sketch oSketch = oCD.Sketches.Add(oPlaneXY) oSketch.Name = "My_Sketch"
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Public Sub Main() ' Get the active part document. Dim partDoc As PartDocument partDoc = ThisApplication.ActiveDocument Dim partDef As PartComponentDefinition partDef = partDoc.ComponentDefinition ' Create a new sketch. Dim sketch As PlanarSketch sketch = partDef.Sketches.Add(partDef.WorkPlanes.Item(3)) Dim tg As TransientGeometry tg = ThisApplication.TransientGeometry ThisApplication.ActiveView.Fit End Sub
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
That was close!
Arthur Knoors
Hey Sergio,
The code works great on parts, however, when I try it on the flat pattern of a sheet metal part, it doesn't run it. How would the code change for the flat pattern? Also, is there a way to create a Text onto the newly created sketch using iLogic only?
Best regards,
Felix Cortes
Hi, if what you are looking for is to create a sketch in the flatt pattern, I think that a simple ilogic code like the following could be useful.
Dim oPartDoc As PartDocument = ThisDoc.Document 'verify document type is sheet metal If oPartDoc.ComponentDefinition.Type <> 150995200 Then MessageBox.Show("File is not a sheet metal part.", "iLogic") Exit Sub End If Dim oCompDef As SheetMetalComponentDefinition oCompDef = oPartDoc.ComponentDefinition ' Check to make sure a flat pattern is open. If Not TypeOf ThisApplication.ActiveEditObject Is FlatPattern Then Try If oCompDef.HasFlatPattern = False Then oCompDef.Unfold 'Else 'oCompDef.FlatPattern.Edit End If Catch MessageBox.Show("Error editting the flat pattern.", "iLogic") End Try End If ' a reference to the active flat pattern. Dim oFlatPattern As FlatPattern = oCompDef.FlatPattern Dim oFace As Face = oFlatPattern.TopFace ' = oFlatPattern.BottomFace Dim oSketch As PlanarSketch oSketch = oFlatPattern.Sketches.Add(oFace) oSketch.Name = "My_Sketch"
I hope the code is useful for you. regards
Mechanical Designer
Excuse me, I just saw that you wanted to add a text, I hope the final lines can be used to give you an idea, maybe by modifying them for a later use. Regards!
' a reference to the active document. Dim oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument 'verify document type is sheet metal If oPartDoc.ComponentDefinition.Type <> 150995200 Then MessageBox.Show("File is not a sheet metal part.", "iLogic") Exit Sub End If Dim oCompDef As SheetMetalComponentDefinition oCompDef = oPartDoc.ComponentDefinition ' Check to make sure a flat pattern is open. If Not TypeOf ThisApplication.ActiveEditObject Is FlatPattern Then Try If oCompDef.HasFlatPattern = False Then oCompDef.Unfold 'Else 'oCompDef.FlatPattern.Edit End If Catch MessageBox.Show("Error editting the flat pattern.", "iLogic") End Try End If ' a reference to the active flat pattern. Dim oFlatPattern As FlatPattern = oCompDef.FlatPattern' ThisApplication.ActiveEditObject Dim oFace As Face = oFlatPattern.TopFace ' = oFlatPattern.BottomFace Dim oSketch As PlanarSketch oSketch = oFlatPattern.Sketches.Add(oFace)', False) oSketch.Name = "My_Sketch" '-------------------------------------------------- Dim sText As String = "Here is the last and final line of text." Dim oTG As TransientGeometry = ThisApplication.TransientGeometry oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(oSketch.OriginPointGeometry.X, _ oSketch.OriginPointGeometry.Y), sText)
Mechanical Designer
Hi Sergio,
I am attempting to rotate the text to 90 degrees. I've tried the following code but it doesn't seem to work.
' a reference to the active document. Dim oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument 'verify document type is sheet metal If oPartDoc.ComponentDefinition.Type <> 150995200 Then MessageBox.Show("File is not a sheet metal part.", "iLogic") Exit Sub End If Dim oCompDef As SheetMetalComponentDefinition oCompDef = oPartDoc.ComponentDefinition ' Check to make sure a flat pattern is open. If Not TypeOf ThisApplication.ActiveEditObject Is FlatPattern Then Try If oCompDef.HasFlatPattern = False Then oCompDef.Unfold 'Else 'oCompDef.FlatPattern.Edit End If Catch MessageBox.Show("Error editting the flat pattern.", "iLogic") End Try End If ' a reference to the active flat pattern. Dim oFlatPattern As FlatPattern = oCompDef.FlatPattern' ThisApplication.ActiveEditObject Dim oFace As Face = oFlatPattern.TopFace ' = oFlatPattern.BottomFace Dim oSketch As PlanarSketch oSketch = oFlatPattern.Sketches.Add(oFace)', False) oSketch.Name = "My_Sketch" '-------------------------------------------------- Dim sText As String = "Here is the last and final line of text." Dim oTG As TransientGeometry = ThisApplication.TransientGeometry 'oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(oSketch.OriginPointGeometry.X, _ ' oSketch.OriginPointGeometry.Y), sText) oTextBox = oSketch.TextBoxes.AddByRectangle(oTG.CreatePoint2d(oSketch.OriginPointGeometry.X, _ oSketch.OriginPointGeometry.Y), oTG.CreatePoint2d(0,2), sText) 'oTextBox = oSketch.TextBoxes.AddFitted 'oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(oSketch.OriginPointGeometry.Y, _ ' oSketch.OriginPointGeometry.X), sText) oTextBox.RotateSketchObjects(oSketch,oTG.CreatePoint2d(oSketch.OriginPointGeometry.X, oSketch.OriginPointGeometry.Y), 90)
Best regards,
Felix Cortes
Hi Felix !, Try this code, I hope you can be useful! I found the access in the API. Best regards!
' a reference to the active document. Dim oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument 'verify document type is sheet metal If oPartDoc.ComponentDefinition.Type <> 150995200 Then MessageBox.Show("File is not a sheet metal part.", "iLogic") Exit Sub End If Dim oCompDef As SheetMetalComponentDefinition oCompDef = oPartDoc.ComponentDefinition ' Check to make sure a flat pattern is open. If Not TypeOf ThisApplication.ActiveEditObject Is FlatPattern Then Try If oCompDef.HasFlatPattern = False Then oCompDef.Unfold 'Else 'oCompDef.FlatPattern.Edit End If Catch MessageBox.Show("Error editting the flat pattern.", "iLogic") End Try End If ' a reference to the active flat pattern. Dim oFlatPattern As FlatPattern = oCompDef.FlatPattern' ThisApplication.ActiveEditObject Dim oFace As Face = oFlatPattern.TopFace ' = oFlatPattern.BottomFace Dim oSketch As PlanarSketch oSketch = oFlatPattern.Sketches.Add(oFace)', False) oSketch.Name = "My_Sketch" '-------------------------------------------------- Dim sText As String = "Here is the last and final line of text." Dim oTG As TransientGeometry = ThisApplication.TransientGeometry oTextBox = oSketch.TextBoxes.AddByRectangle(oTG.CreatePoint2d(oSketch.OriginPointGeometry.X, _ oSketch.OriginPointGeometry.Y), oTG.CreatePoint2d(0,2), sText) ' supports only 0, pi/2, pi, 1.5pi oTextBox.Rotation = PI/2 'Math.Atan(1) * 2
Mechanical Designer
