Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic errors after update inventor 2018
15 REPLIES 15
Message 1 of 16
m.maertens6DTZT
1202 Views, 15 Replies
Hi all,
When I want to use an iLogic component from inventor 2016 in 2018, I receive an error.
See below:
To make things more complex; when I send this file to my collegue, he don't receive this issue.
Can you please open the file and see if you also can repeat this issue?
And most important: any idea how to solve this
Thanks!
Best regards
15 REPLIES 15
Message 2 of 16
For me the code properties runs correct..
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Message 3 of 16
What version of inventor are you and your colleague using?
Arthur Knoors
Message 4 of 16
JaneFan
in reply to: m.maertens6DTZT
It runs correctly for me, too.
Is the file in library folder? Please try to add this line in Properties rule:
SyntaxEditor Code Snippet
ThisApplication.[_LibraryDocumentModifiable] = True
Jane Fan
Inventor QA Engineer
Message 5 of 16
m.maertens6DTZT
in reply to: JaneFan
No, because I just can't modify anything or save it in the properties.
I can't even change the name. I always get this message:
Message 6 of 16
Put a messagebox in each if and before each if. Take a look what happens
Arthur Knoors
Message 7 of 16
Thanks yor your reply.
See below the screenshot of the version that I use.
I have 2 collegues, but it only works with 1 of them.
The other collegue and myself are having this issue.
Message 8 of 16
Van you please provide the details of the error. Error tab....
Arthur Knoors
Message 9 of 16
So, when I open an iLogic component - I get the error message: Error in rule: Properties, in document: Fixscreen 124D 186D 100S.ipt
On the tab 'more info' I have this:
System.Runtime.InteropServices.COMException (0x80004005): Niet nader omschreven fout (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.Property.set_Value(Object )
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
When I go into the rules of my iLogic browser and I try to modify anything,  I get an error message.
I just don't get it how this suddenly doesn't work anymore
Message 10 of 16
Arthur Knoors
Message 11 of 16
Ok,
I managed to make it work by changing my projects.
FYI: We work with several projects in inventor.
Same as in 2016 - but it seems that in 2018 something has changed.
Projects "02 Projecten (ETO)" is to make all our projects and to import the parts from our library. When I work in this projects, I receive the error!
Projects "02 beCAD 2018" is when we want to modify our library. When I work in this, it works!
So, probably it has something to do with read/write - read only. error message .jpg
The strange thing is that this way of working works in 2016 but nog in 2018 anymore.
Message 12 of 16
JaneFan
There is a change between 2016 and 2018 which might be the cause that modifying library files or read only files from API/iLogic are blocked by default, for security sack. But if users need it, there is an option to enable this function by setting inventor application property _LibraryDocumentModifiable to True:
Jane Fan
Message 13 of 16
This has been changed in 2018. You are correct.
Good to hear that it works now for you.
They have implemented a property to allow library changed in inventor" librarymofifyable"
Arthur Knoors
Message 14 of 16
Not exactly.
When I add this rule to the properties, I don't receive the error anymore. So that is solved 🙂
But, when I modify the values in the iLogic window that pops up, then the parts of my library are modified. And this can't be correct.
In 2016, when I insert this specific iLogic component, then it generates copies of the adapted part into my project folder.
See below how this works in 2016.
Step 1: insert iLogic component
Step 2: automatically generating copys of the modified part into the project folder.
To make things more complex again. With another, more simplistic model, it does the job correctly = copy the modified parts into the library.
I know, it's perhaps not easy to follow exactly what I mean because our library and way of working is customized for our purpose.
I just want to mention this because: in 2016 this works fine and in 2018 not for all components.
I will also try to figure this out by deleting all the rules and adding them step by step again.
Message 15 of 16
I replaced the files that are necessary for the ilogic component in a new folder and called that "PARTS".
see folder structure below.
And I also added the text in the rule.
Now, whenever I import the ilogic component - it creates the files in my project folder.
Thanks for all your helpfull feedback!
Message 16 of 16
Your thanks are appreciated!
Arthur Knoors
