i copy and paste a code that exports the partlist from an IDW in a folder, Excel Format. The Problem is, if the partlist is placed on sheet:2 (blatt:2) or somewhere else.
Please can you Change the code, that it exports the partlist where ever the list is placed.
Thanks in advance!
Regards from germany
Martin
DocType = ThisDoc.Document.DocumentType If DocType <> DocumentTypeEnum.kDrawingDocumentObject Then MessageBox.Show("Diese Funktion ist nur in einer Zeichnungsableitung zulässig. Abbruch! ", "nur in Zeichnung", MessageBoxButtons.OK, MessageBoxIcon.Error) Exit Sub End If Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument If oDrawDoc.ActiveSheet.PartsLists.Count = 0 Then MessageBox.Show("Keine Stückliste vorhanden. Abbruch! ", "Keine Stückliste", MessageBoxButtons.OK, MessageBoxIcon.Error) Exit Sub ElseIf oDrawDoc.ActiveSheet.PartsLists.Count > 1 Then MessageBox.Show("Es sind mehrere Stücklisten vorhanden, die Erste im Browser wird für den Export verwendet", "mehrere Stückliste", MessageBoxButtons.OK, MessageBoxIcon.Information) End If Dim oPartList As PartsList oPartList = oDrawDoc.ActiveSheet.PartsLists.Item(1) Dim oPartsList1 As PartsList oPartsList1 = oDrawDoc.ActiveSheet.PartsLists.Item(1) Dim sAuthor, sPath, sFilename, sTXTFileName As String Dim oPropSet As PropertySet sPath = "x:\input\" Dim oRefedDoc As Document oRefedDoc = oPartlist.ReferencedDocumentDescriptor.ReferencedDocument sAuthor = oRefedDoc.propertySets(1) ("Author").Value If sAuthor = "" Then MessageBox.Show("Keine Artikelnummer in Datei " & oRefedDoc.FullDocumentName & " vergeben. Abbruch! ", "leeres iProp", MessageBoxButtons.OK, MessageBoxIcon.Error) Exit Sub End If sFilename = sAuthor & ".txt" sTXTFileName = sPath & sFilename Dim oDoc As Inventor.DrawingDocument oDoc = ThisDoc.Document Dim oSheet As Inventor.Sheet oSheet = oDoc.Sheets("Blatt:1") ' sheet by name Dim oPartslist As PartsList oPartslist = oSheet.PartsLists(1) oPartslist.Export(sTXTFilename,PartsListFileFormatEnum.kTextFileTabDelimited) MessageBox.Show("Die Exportdatei der Stückliste wurde im Verzeichnis X:\INPUT\ gespeichert", "Export TXT", MessageBoxButtons.OK, MessageBoxIcon.Information)
Solved by bradeneuropeArthur. Go to Solution.
for each sheet in odrawdoc.sheets
oPartList = sheet.PartsLists.Item(1)
sPath = "x:\input\"
Exit Sub
'Dim oSheet As Inventor.Sheet
'oSheet = oDoc.Sheets("Blatt:1") ' sheet by name
'Dim oPartslist As PartsList
'oPartslist = oSheet.PartsLists(1)
next
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Hello Brandeurope,
thanks for your reply. Your change is looking through all Sheets and stops with a message:
bei iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
I think the Problem is, if i have a partlist on sheet:1 and NO partlist on sheet:2.
It can happen that i have several sheets but only two of them have a partlist - the right one that i like to Export is the first one in the browser.
Thanks again for your help!
Regards Martin
try this I am not at my desk but I put this together:
Public Sub pl() Dim oDoc As Inventor.DrawingDocument oDoc = ThisDoc.Document Dim oSheet As Inventor.Sheet edit .............................'oSheet = oDoc.Sheets("Blatt:1") ' sheet by name edit Dim oPartslist As PartsList DocType = ThisDoc.Document.DocumentType If DocType <> DocumentTypeEnum.kDrawingDocumentObject Then Exit Sub End If Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument For Each oSheet In oDrawDoc.Sheets oSheet.Activate If oDrawDoc.ActiveSheet.PartsLists.Count = 0 Then Exit Sub ElseIf oDrawDoc.ActiveSheet.PartsLists.Count > 1 Then End If Next Dim oPartList As PartsList oPartList = oDrawDoc.ActiveSheet.PartsLists.Item(1) Dim oPartsList1 As PartsList oPartsList1 = oDrawDoc.ActiveSheet.PartsLists.Item(1) Dim sAuthor, sPath, sFilename, sTXTFileName As String Dim oPropSet As PropertySet sPath = "x:\input\" Dim oRefedDoc As Document oRefedDoc = oPartList.ReferencedDocumentDescriptor.ReferencedDocument sAuthor = oRefedDoc.PropertySets(1)("Author").Value If sAuthor = "" Then Exit Sub End If sFilename = sAuthor & ".txt" sTXTFileName = sPath & sFilename oPartslist = oSheet.PartsLists(1) oPartslist.Export(sTXTFileName, PartsListFileFormatEnum.kTextFileTabDelimited) End Sub
Arthur Knoors
edit:
Public Sub pl() Dim oDoc As Inventor.DrawingDocument Set oDoc = ThisApplication.ActiveDocument Dim oSheet As Inventor.Sheet 'Set oSheet = oDoc.Sheets.Item(1) ' sheet by name Dim oPartslist As PartsList 'DocType = ThisDoc.Document.DocumentType If oDoc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Exit Sub End If Dim oDrawDoc As DrawingDocument Set oDrawDoc = ThisApplication.ActiveDocument For Each oSheet In oDrawDoc.Sheets MsgBox oSheet.Name oSheet.Activate If oDrawDoc.ActiveSheet.PartsLists.Count = 0 Then 'Exit Sub ElseIf oDrawDoc.ActiveSheet.PartsLists.Count > 1 Then Dim oPartList As PartsList oPartList = oDrawDoc.ActiveSheet.PartsLists.Item(1) Dim oPartsList1 As PartsList oPartsList1 = oDrawDoc.ActiveSheet.PartsLists.Item(1) Dim sAuthor, sPath, sFilename, sTXTFileName As String Dim oPropSet As PropertySet sPath = "x:\input\" Dim oRefedDoc As Document oRefedDoc = oPartList.ReferencedDocumentDescriptor.ReferencedDocument sAuthor = oRefedDoc.PropertySets(1)("Author").Value If sAuthor = "" Then Exit Sub End If sFilename = sAuthor & ".txt" sTXTFileName = sPath & sFilename oPartslist = oSheet.PartsLists(1) Call oPartslist.Export(sTXTFileName, PartsListFileFormatEnum.kTextFileTabDelimited) End If Next End Sub
Arthur Knoors
