Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Get Part Parameter name from assembly
2 REPLIES 2
karl.leduc-berard
355 Views, 2 Replies
im trying to create a Function to find a part in my assembly and then find in it a parameter which can be a model or a user parameter.
But the farthest i could go is to look into assembly parameters....
Any Idea?
Here is my code so far.
Function fuFindPartParam(ByVal sVar1 as string, ByVal sVar2 as string, ByVal sVar3 as string) as string
Dim oDoc As AssemblyDocument
oDoc = ThisDoc.Document
Dim oComps As ComponentOccurrences
oComps = oDoc.ComponentDefinition.Occurrences
For Each oComp In oComps
    If oComp.Name = sVar3 Then
        For Each oParameter In oComp.Definition.Parameters.ModelParameters
             If oParameter.Name.Contains(sVar1) And oParameter.Name.Contains(sVar2) Then
                   Return oParameter.Name
        Next
Next
        For Each oParameter In oComp.Definition.Parameters.UserParameters
        Next
Next
End Function
2 REPLIES 2
@karl.leduc-berard,
Hope this below code may be helpful.
Function fuFindPartParam(ByVal sVar1 As String, ByVal sVar2 As String, ByVal sVar3 As String) As String
             If oParameter.Name.Contains(sVar1) Or oParameter.Name.Contains(sVar2) Then
        Next
Next
End Function
Thanks and regards
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
thanks!
Technology Administrators
