@karl.leduc-berard,
Hope this below code may be helpful.
Function fuFindPartParam(ByVal sVar1 As String, ByVal sVar2 As String, ByVal sVar3 As String) As String
Dim oDoc As AssemblyDocument
oDoc = ThisDoc.Document
Dim oComps As ComponentOccurrences
oComps = oDoc.ComponentDefinition.Occurrences
For Each oComp In oComps
    If oComp.Name = sVar3 Then
        For Each oParameter In oComp.Definition.Parameters
             If oParameter.Name.Contains(sVar1) Or oParameter.Name.Contains(sVar2) Then
                   Return oParameter.Name
             End If
        Next
    End If
Next
End Function
Thanks and regards
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
