- Mute
- Permalink
- Report
im trying to create a Function to find a part in my assembly and then find in it a parameter which can be a model or a user parameter.
But the farthest i could go is to look into assembly parameters....
Any Idea?
Here is my code so far.
Dim oDoc As AssemblyDocument
oDoc = ThisDoc.Document
Dim oComps As ComponentOccurrences
oComps = oDoc.ComponentDefinition.Occurrences
For Each oComp In oComps
If oComp.Name = sVar3 Then
For Each oParameter In oComp.Definition.Parameters.ModelParameters
If oParameter.Name.Contains(sVar1) And oParameter.Name.Contains(sVar2) Then
Return oParameter.Name
End If
Next
End If
Next
For Each oParameter In oComp.Definition.Parameters.UserParameters
End If
Next
End If
Next
End Function
