I need to get the related item quantity and part number but I can't get it because the quantity is available in the ComponentDefinition.BOM and the item number is available in the oAsmCompDef.Occurrences.
How do it ?
Thanks for your help
How do it ?
Solved by bradeneuropeArthur. Go to Solution.
Are you looking to get part quantity in an assembly in the drawing of the part or part itself? You will need to pass the qty from assembly or assembly drawing into the part drawing or individual part.
Can you explain a little more the workflow you require with some images or sample files?
I need to have the quantity of each part in the assembly and its part number.
I can find this information, but I cannot relate it to each other.
I can find the quantity but I do not know exactly what is the quantity of which piece.
Can't you use the BOM for it?
With this:
Public Sub BOMQuery()
' Set a reference to the assembly document.
' This assumes an assembly document is active.
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim FirstLevelOnly As Boolean
If MsgBox("First level only?", vbYesNo) = vbYes Then
FirstLevelOnly = True
Else
FirstLevelOnly = False
End If
' Set a reference to the BOM
Dim oBOM As BOM
Set oBOM = oDoc.ComponentDefinition.BOM
' Set whether first level only or all levels.
If FirstLevelOnly Then
oBOM.StructuredViewFirstLevelOnly = True
Else
oBOM.StructuredViewFirstLevelOnly = False
End If
' Make sure that the structured view is enabled.
oBOM.StructuredViewEnabled = True
'Set a reference to the "Structured" BOMView
Dim oBOMView As BOMView
Set oBOMView = oBOM.BOMViews.Item("Structured")
Debug.Print "Item"; Tab(15); "Quantity"; Tab(30); "Part Number"; Tab(70); "Description"
Debug.Print "----------------------------------------------------------------------------------"
'Initialize the tab for ItemNumber
Dim ItemTab As Long
ItemTab = -3
Call QueryBOMRowProperties(oBOMView.BOMRows, ItemTab)
End Sub
Private Sub QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator, ItemTab As Long)
ItemTab = ItemTab + 3
' Iterate through the contents of the BOM Rows.
Dim i As Long
For i = 1 To oBOMRows.Count
' Get the current row.
Dim oRow As BOMRow
Set oRow = oBOMRows.Item(i)
'Set a reference to the primary ComponentDefinition of the row
Dim oCompDef As ComponentDefinition
Set oCompDef = oRow.ComponentDefinitions.Item(1)
Dim oPartNumProperty As Property
Dim oDescripProperty As Property
If Typeof oCompDef Is VirtualComponentDefinition Then
'Get the file property that contains the "Part Number"
'The file property is obtained from the virtual component definition
Set oPartNumProperty = oCompDef.PropertySets _
.Item("Design Tracking Properties").Item("Part Number")
'Get the file property that contains the "Description"
Set oDescripProperty = oCompDef.PropertySets _
.Item("Design Tracking Properties").Item("Description")
Debug.Print Tab(ItemTab); oRow.ItemNumber; Tab(17); oRow.ItemQuantity; Tab(30); _
oPartNumProperty.Value; Tab(70); oDescripProperty.Value
Else
'The file property is obtained from the parent
'document of the associated ComponentDefinition.
Set oPartNumProperty = oCompDef.Document.PropertySets _
Set oDescripProperty = oCompDef.Document.PropertySets _
'Recursively iterate child rows if present.
If Not oRow.ChildRows Is Nothing Then
Call QueryBOMRowProperties(oRow.ChildRows, ItemTab)
End If
End If
Next
ItemTab = ItemTab - 3
End Sub
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
With this:
Else
End If
Dim oBOM As BOM
Else
End If
Dim ItemTab As Long
ItemTab = -3
End Sub
Dim i As Long
Dim oRow As BOMRow
Else
End If
End If
Next
End Sub
Arthur Knoors
