Get focus on Inventor after using a Button on a Form
5 REPLIES 5
checkcheck_master
255 Views, 5 Replies
Hello.
If I have used a Button on a Form, I must first click in Inventor to access it again.
I'm trying to get focus using this code but it doesn't seem to work.
'Set focus back to Inventor application
Dim App As Process() = Process.GetProcessesByName("Inventor 2022")
If App.Length > 0 Then
	AppActivate(App(0).Id)
End If
Anyone?
Labels (1)
5 REPLIES 5
What do you use:
form.show
or
form.showdialog
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Neither, I mean a Global Form that is open next to Inventor with some buttons on it that address another External Rule.
See picture.
@bradeneuropeArthur
This is the setup from the form, see picture.
I need to see the code of the form and of the button!
Arthur Knoors
That is a collection of separate rules, see zip as attachment.
Form in 'UI' zip.
Most rules are a 'pass through' to the 'main' rule 'Scale Position Views' according:
' Check file type
If ThisApplication.ActiveDocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
	Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
	' Run external rule with parameters
	' Fill argument's list
	Dim map As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
	Dim SetScale As String = "Scale All Bigger"
	map.Add("SetScale", SetScale)
	auto = iLogicVb.Automation
	auto.RunExternalRuleWithArguments(oDoc, "Scale Position Views", map)
End If
In other words, 'Scale Position Views' is the linchpin in the whole.
I also try to get the focus there at the end.
See 'Scale Position Views' code:
'Dim obj As DrawingView
'	obj = RuleArguments("DrawingView")
'	AddBallonToView(obj)
'MessageBox.Show(RuleArguments("ScaleAllBigger"))
Dim SetScale As String = RuleArguments("SetScale")
Dim SetSheetFormat As String = RuleArguments("SetSheetFormat")
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oView As DrawingView
Dim lScales As New List(Of Double)
lScales.AddRange({0.2, 0.25, 0.333333333333, 0.5, 1, 2, 3, 4, 5, 6, 8, 10, 12, 15, 20, 25, 30, 40, 50, 75, 100 })
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oSheetWidth As Double = oDoc.ActiveSheet.Width
Dim oSheetHeight As Double = oDoc.ActiveSheet.Height
Dim oTitleBlock As TitleBlock = oSheet.TitleBlock
Dim oSideBorderOffset As Double = (0.5)
Dim oTopBottomBorderOffset As Double = (0.5)
Dim oTitleBlockHeight As Double = (6.5)
' Set PartsList position
Dim x As Double = 0
Dim y As Double = 0
Try
	Dim oPartsList As PartsList
	oPartsList = oSheet.PartsLists.Item(1)
	'								Dim insertPoint As Point2d = oTG.CreatePoint2d(0, 0)
	'								Dim PartsList As PartsList = oSheet.PartsLists.Add(oSheet.DrawingViews.Item(1), insertPoint)
	'							    Dim ooPartsList As PartsList = oSheet.PartsLists.Add(oSheet.DrawingViews.Item(1), insertPoint, PartsListLevelEnum.kPartsOnly)
	'								ooPartsList.HeadingPlacement = HeadingPlacementEnum.kHeadingAtBottom
	'								ooPartsList.TableDirection = TableDirectionEnum.kBottomUpDirection
	Dim plHeight = oPartsList.RangeBox.MaxPoint.Y - oPartsList.RangeBox.MinPoint.Y
	Dim plWidth = oPartsList.RangeBox.MaxPoint.X - oPartsList.RangeBox.MinPoint.X
	'MessageBox.Show("plWidth: " & plWidth)
	x = oTitleBlock.RangeBox.MaxPoint.X
	y = oTitleBlock.RangeBox.MaxPoint.Y + plHeight
	oPartsList.Position = oTG.CreatePoint2d(x, y)
	oPartsList.PartsListRows(0).Height = 5
	For Each oRow In oPartsList.PartsListRows
		oRow.Height = .5
	Next
Catch
End Try
' Located at the beginning of the rule to keep it as fast as possible
' If the views are already unsuppressed then calulate/position them again
Dim bAllViewsAlreadyUnsuppressed As Boolean = True
If SetScale = "Unsuppress Aditional Views" Then
	For Each oView In oSheet.DrawingViews
		If oView.Suppressed = True Then
			oView.Suppressed = False
		Else
			bAllViewsAlreadyUnsuppressed = False
		End If
		'xMin = oView.Left
		'xMax = oView.Left + oView.Width
		'yMin = oView.Top - oView.Height
		'yMax = oView.Top
		'If xMax < 0 Or xMin > oSheetWidth Or yMax < 0 Or yMin > oSheetHeight Then oView.ShowLabel = True ' View = outside border
	Next
	If bAllViewsAlreadyUnsuppressed = True Then Exit Sub
End If
' Undo Wrapper
Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(oDoc, "Do your thing")
' Determine the Distances between Views to maintain after scaling
Dim oDistBaseRightView As Double
Dim oDistBaseTopView As Double
Dim oDistBaseLeftView As Double
Dim oDistRightBackView As Double
Dim oDistBaseBottomView As Double
Dim oDistBaseBackView As Double
Dim xMaxBase As Double ' = ActiveSheet.View("BASE VIEW").Center.X
Dim xMinBase As Double
Dim yMaxBase As Double
Dim yMinBase As Double
Dim xMinRight As Double
Dim xMaxRight As Double
Dim yMinTop As Double
Dim xMaxLeft As Double
Dim xMinBack As Double
Dim yMaxBottom As Double
Dim oBaseView As DrawingView ' = oSheet.DrawingViews("BASE VIEW")
Dim oRightView As DrawingView
Dim oTopView As DrawingView
Dim oLeftView As DrawingView
Dim oBackView As DrawingView
Dim oBottomView As DrawingView
Dim oISOFrontView As DrawingView
Dim oISOLeftView As DrawingView
Dim oISOFrontBottomView As DrawingView
Dim oISOLeftBottomView As DrawingView
Dim oISORightView As DrawingView
Dim oISOBackView As DrawingView
Dim oISORightBottomView As DrawingView
Dim oISOBackBottomView As DrawingView
	If oView.Name = "BASE VIEW" Then
		oBaseView = oView
		xMaxBase  = oView.Left + oView.Width
		xMinBase  = oView.Left
		yMaxBase  = oView.Top
		yMinBase  = oView.Top - oView.Height
	End If
	If oView.Name = "RIGHT VIEW" Then
		oRightView = oView
		xMinRight = oView.Left
		xMaxRight = oView.Left + oView.Width
	End If
	If oView.Name = "TOP VIEW" Then
		oTopView = oView
		yMinTop = oView.Top - oView.Height
	End If
	If oView.Name = "LEFT VIEW" Then
		oLeftView = oView
		xMaxLeft = oView.Left + oView.Width
	End If
	If oView.Name = "BACK VIEW" Then
		oBackView = oView
		xMinBack = oView.Left
	End If
	If oView.Name = "BOTTOM VIEW" Then
		oBottomView = oView
		yMaxBottom = oView.Top
	End If
Next
oDistBaseRightView 	= xMinRight - xMaxBase
oDistBaseTopView 	= yMinTop - yMaxBase
oDistBaseLeftView 	= xMinBase - xMaxLeft
oDistRightBackView  = xMinBack - xMaxRight
oDistBaseBottomView = yMinBase - yMaxBottom
oDistBaseBackView   = xMinBack - xMaxBase
	Try
		xMin = oView.Left
		yMax = oView.Top
		xTarget  = 0
		xCurrent = 0
		yTarget  = 0
		yCurrent = 0
		x = oView.Center.X
		y = oView.Center.Y
		If SetScale = "Scale All Bigger" Then
			Dim oBViewScale As Double = (1 / oView.Scale)
			Dim Val As Double = lScales.IndexOf(oBViewScale)
			Try
				oView.Scale = 1 / lScales.Item(Val - 1)
			Catch
			End Try
		End If
		If SetScale = "Scale All Smaller" Then
				Try
					oView.Scale = 1 / lScales.Item(Val + 1)
				Catch
				End Try
		End If
		If SetScale = "Scale ISO Bigger" Then
			If oView.Name Like "*ISO*" Then
				Try
				Catch
				End Try
			End If
		End If
		If SetScale = "Scale ISO Equal" Then
				oView.Scale = (oSheet.DrawingViews.Item(1).Scale)
			End If
		End If
		If SetScale = "Scale ISO Smaller" Then
				Try
				Catch
				End Try
			End If
		End If
		If SetScale = "Scale ISO Standard Position" Then
			' See below in Code under 'If oView.Name = "ISO FRONT VIEW" Then'
		End If
		If SetScale = "Scale Other Bigger" Then
			If Not oView.Name Like "*ISO*" Then
				Try
				Catch
				End Try
			End If
		End If
		If SetScale = "Scale Other Smaller" Then
				Try
				Catch
				End Try
			End If
		End If
			' See above in Code
		End If
		If SetScale = "Suppress Aditional Views" Then
			If xMax < 0 Or xMin > oSheetWidth Or yMax < 0 Or yMin > oSheetHeight Or xMax > oSheetWidth or xMin < 0  Or yMax > oSheetHeight Or yMin < 0 Then ' View = outside border
			End If
		End If
			oBaseView = oView
			oView.Center = oTG.CreatePoint2d((oView.Width / 2) + xMin , y)
			oview.ShowLabel = False
		End If
			oRightView = oView
			If (xMax < 0 Or xMin > oSheetWidth Or yMax < 0 Or yMin > oSheetHeight Or xMax > oSheetWidth Or xMin < 0) And oView.ShowLabel = True Then  ' View = outside border
				RightViewIsOutsideBorder = True ' To set BackView when RightView is outside border
				xTarget = oSheetWidth + 5
				xCurrent = xMin
			Else
				oView.ShowLabel = False
				xTarget = oBaseView.Left + oBaseView.Width + oDistBaseRightView
				xCurrent = oView.Left
			End If
			oView.Center = oTG.CreatePoint2d(oView.Position.X + (xTarget - xCurrent), oView.Position.Y + (yTarget - yCurrent))
		End If
			oTopView = oView
			If (xMax < 0 Or xMin > oSheetWidth Or yMax < 0 Or yMin > oSheetHeight Or yMax > oSheetHeight Or yMin < 0) And oView.ShowLabel = True Then ' View = outside border
				yTarget = oSheetHeight + 5
				yCurrent = oView.Top - oView.Height
			Else
				yTarget = oBaseView.Top + oDistBaseTopView
			End If
		End If
			oLeftView = oView
				xTarget = 0 - 5 - oView.Width
				xCurrent = xMin
			Else
				xTarget = oBaseView.Left - oDistBaseLeftView - oView.Width
			End If
		End If
			oBackView = oView
			If (xMax < 0 Or xMin > oSheetWidth Or yMax < 0 Or yMin > oSheetHeight Or xMax > oSheetWidth or xMin < 0) And oView.ShowLabel = True Then ' View = outside border
					If RightViewIsOutsideBorder Then xTarget = oSheetWidth + 7 + oRightView.Width + 3 ' Place at right side from oRightView which is outside border
				xCurrent = xMin
			Else
				xTarget = oRightView.Left + oRightView.Width + oDistRightBackView
					If RightViewIsOutsideBorder Then xTarget = oBaseView.Left + oBaseView.Width + oDistBaseBackView ' Place at right side from oRightView which is outside border
				xCurrent = xMin
			End If
		End If
			oBottomView = oView
				yTarget = 0 - 5 - oView.Height
			Else
				yTarget = oBaseView.Top - oBaseView.Height - oDistBaseBottomView - oView.Height
			End If
		End If
			oISOFrontView = oView
			If xMax < 0 Or xMin > oSheetWidth Or yMax < 0 Or yMin > oSheetHeight Then ' View = outside border
			Else
					xTarget = oSheetWidth - oSideBorderOffset - 1 - oView.Width
					yTarget = oSheetHeight - oTopBottomBorderOffset - 1 - oView.Height
				Else
					xTarget = xMax - oView.Width
					yTarget = yMax - oView.Height
				End If
			End If
		End If
		If oView.Name = "ISO LEFT VIEW" Then
			oISOLeftView = oView
				xTarget = 0 - 5 - oISOFrontView.Width - 5 - oView.Width
			Else
			End If
		End If
		If oView.Name = "ISO FRONT BOTTOM VIEW" Then
			oISOFrontBottomView = oView
			Else
			End If
		End If
		If oView.Name = "ISO LEFT BOTTOM VIEW" Then
			oISOLeftBottomView = oView
				xTarget = 0 - 5 - oISOFrontBottomView.Width - 5 - oView.Width
			Else
			End If
		End If
		If oView.Name = "ISO RIGHT VIEW" Then
			oISORightView = oView
			Else
			End If
		End If
		If oView.Name = "ISO BACK VIEW" Then
			oISOBackView = oView
				xTarget = oSheetWidth + 5 + oISORightView.Width + 5
			Else
			End If
		End If
		If oView.Name = "ISO RIGHT BOTTOM VIEW" Then
			oISORightBottomView = oView
			Else
			End If
		End If
		If oView.Name = "ISO BACK BOTTOM VIEW" Then
			oISOBackBottomView = oView
			Else
			End If
		End If
	Catch
	End Try
Next
' Undo Wrapper
trans.End()
''Set focus back to Inventor application
'Dim App As Process() = Process.GetProcessesByName("Inventor 2022")
'If App.Length > 0 Then
'	AppActivate(App(0).Id)
'End If
Technology Administrators
