Export Inventor sheet metal part file to DXF by changing the file state in vault?
2 REPLIES 2
diarmuid.bolandJJRTE
167 Views, 2 Replies
Hi Guru's
Is is possible to run an external rule that exists in my sheet metal part file? The external rule in the file flattens the sheet metal part and then creates a dxf file which is then saved into a Temp folder. Is it possible to have this rule triggered to run when the file state is changed to "Released" in Vault? By the way, I am currently running Inventor and vault professional 2021.
2 REPLIES 2
You might want to have a look at this AU class :
https://www.autodesk.com/autodesk-university/class/iLogic-and-Vault-Vault-and-iLogic-2020
One of the key learnings is:
"Learn how to solve automation tasks by running iLogic rules as custom Jobs in Vault Job Processor."
Exporting a sheet metal part using an iLogic rule is not that difficult.
You can run custom jobs using your lifecycle settings. For example, if you change the status to released 😉
Jelte de Jong
Blog: hjalte.nl - github.com
You will need to create a new jobprocess for  the Vault jobserver for this.
This job can than be added to the action to take place when the file is released.
I have created similar jobproces fo creating partslist exports in/to Excel, in a _Xls folder of the project in Vault.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
