I've created an add-in for Inventor, using a dockable window. My issue is that when I completely close Inventor, my dockable window also disappears, and I have to bring it back every time. This is my first time working with a Dockable Window, and I created it using Hjalte's tutorial, where I made use of a 'DockableWindowChildAdapter'.
You need to use the application events to bring it to front again.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
