Is it possible to convert iAssembly/iPart factory to normal assembly using iLogic?
I've found the way to delete single rows and columns, but how can I delete the entire Table?
Solved by bradeneuropeArthur. Go to Solution.
Dim a As Application Set a = ThisApplication Dim b As PartDocument Set b = a.ActiveDocument Dim c As iPartFactory Set c = b.ComponentDefinition.iPartFactory c.Delete
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Arthur Knoors
THANK you!
Hello
the code works well with iParts. Deleting an iAssembly table always always throws an exception.
Inventor.AssemblyComponentDefinition assmDef = assmDoc.ComponentDefinition; if (assmDef.IsiAssemblyFactory) { Inventor.iAssemblyFactory factory = assmDef.iAssemblyFactory; factory.Delete(); // throws an exception
Is there any solution?
Regards
Christoph
Edit: Second try with vba:
Hello
Regards
Christoph
not sure, if you still need help, but I had the same problem. The problem were excluded ComponentOccurrences in the iAssembly. Delete them or include them before deleting the iAssemblyFactory and you're fine.
Regards
Michael
Regards
Michael
