Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Chamfer from InnerEdgeLoop API VB.NET
6 REPLIES 6
florian_wenzel
301 Views, 6 Replies
florian_wenzel
inventor 2022
API VB.NET Visual Studio
I try to Select a Face with a Slot, Take the Inside EdgeLoop, and Create a Chamfer on this Slot:
This is the Goal
This is my Code:
    Dim oFaceSlot As Face = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Pick a Face")
        Dim oEdgeloop As EdgeLoop
        Dim oEdge As Edge
        Dim oEdgeColl As EdgeCollection = oTO.CreateEdgeCollection
        For Each oEdgeloop In oFaceSlot.EdgeLoops
            If oEdgeloop.IsOuterEdgeLoop = False Then
                For Each oEdge In oEdgeloop.Edges
                    oEdgeColl.Add(oEdge)
                Next
        Next
        Dim oChamfer As ChamferFeature
        oChamfer = oPart_C_Def.Features.ChamferFeatures.AddUsingDistance(oEdgeColl, 0.5, True)
Error:
Unknow Error
It Works with Fillet
But i Need a Chamfer.
Thanks for Suggestion
inventor 2022
This is the Goal
This is my Code:
        Dim oEdge As Edge
                Next
        Next
Error:
Unknow Error
6 REPLIES 6
Michael.Navara
The code looks fine and it works for me. May be the chamfer size (0.5) is too big for your test case. Dimension units in API is always in centimeters.
florian_wenzel
Hi @Michael.Navara
Still unknow Error:
i also was trying with 0.1 or 0.05  or "0.1"
Stil Error.
Should i Use a Chamfer Definition?
But dont know exactly what to use it?
Hi @Michael.Navara
Still unknow Error:
Stil Error.
Michael.Navara
This is my test case with local iLogic rule
florian_wenzel
Hi @Michael.Navara ,
I check your iLogic Rules, and it work also with Curved Face.
is this Possible that i got Error, because in my Example the Face is not Planar.
This is a Curved Face, do this matter?
Maybe this is the Problem with API?
Is Stange, because the FilletFeature Works Fine.
I only Think, that the Feature still need some Ddefinitions?
Michael.Navara
Can you post your test data, where my code doesn't work?
florian_wenzel
Your iLogic Code is Working, also with Curved Face.
What you mean test data?
