I can add things to an array, but for debugging I'd like to sometimes be able to see what this actually contains, is there a way to do this, or export a txt file or something?
iLogic
for vba?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
No, iLogic. I tried to put a space after the word iLogic above but it wouldn't let me edit the post.
The only way I've managed to do it so far is to loop through the array and send each value to the logger, but this seemed a bit long winded.
https://adndevblog.typepad.com/manufacturing/2014/08/debug-ilogic.html
Arthur Knoors
I know how to debug, my question was, what is the easiest way to view the contents of an array.
Public Sub main() Dim a As Variant a = Array(1, 2, 3) 'MsgBox a(1) MsgBox Join(a, vbCrLf) End Sub
Arthur Knoors
or this:
Public Sub Main() Dim a() As String a = {"1", "2", "3"} MsgBox (Join(a, vbCrLf)) End Sub
Arthur Knoors
