Check contents of array
6 REPLIES 6
SharkDesign
327 Views, 6 Replies
I can add things to an array, but for debugging I'd like to sometimes be able to see what this actually contains, is there a way to do this, or export a txt file or something?
iLogic
  Expert Elite
  Inventor Certified Professional
6 REPLIES 6
for vba?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
No, iLogic. I tried to put a space after the word iLogic above but it wouldn't let me edit the post.
The only way I've managed to do it so far is to loop through the array and send each value to the logger, but this seemed a bit long winded.
  Expert Elite
https://adndevblog.typepad.com/manufacturing/2014/08/debug-ilogic.html
Arthur Knoors
I know how to debug, my question was, what is the easiest way to view the contents of an array.
  Expert Elite
Public Sub main()
Dim a As Variant
a = Array(1, 2, 3)
'MsgBox a(1)
MsgBox Join(a, vbCrLf)
End Sub
Arthur Knoors
or this:
Public Sub Main()
Dim a() As String
a = {"1", "2", "3"}
MsgBox (Join(a, vbCrLf))
End Sub
Arthur Knoors
Technology Administrators
