Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
activate the button of a form before saving a part for the first time
1 REPLY 1
Miguel.CarvajalS34Q6
185 Views, 1 Reply
It is possible to activate a form button before the first time a part or assembly is saved
The gesture would be to click on save, but before saving the form button would be activated and in said form the information and metadata of the part would be filled out to later be saved.
Labels (4)
1 REPLY 1
Via a vb.net form yes. You can use the filesavecounter. This value is 0 when never saved!
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
