hello,
I have a question, it is possible to have a custom property in the part that indicates the surface finish of a part and that when inserting the part in a drawing, the label identifies it and inserts a block with the specification of the surface finish.
I currently create a code to insert a block from the drawing to indicate the surface finish. ex: (N7), but the coordinate in which the block is positioned is the same for all the sheets of the drawing and I would like it to change according to the size of the sheet, that is, if I use an A4 format, the coordinates are the appropriate ones for that format, if I use an A3 the block coordinates are organized according to that format
In summary, I want to give the part a variable called surface finish and choose from a list of possible values, ex: (N7/N5), (N7), (N5) etc. and said value calls the label a block that indicates the surface finish.
