write ipt to iam using ilogic rule
Message 1 of 13
Is it possible to write parameters to an iam file from a part when the ipt doesn't exist in the assembly
Perhaps by defining the ipt file path and then its specific parameter I want to write to?
Replies (12)
Message 2 of 13
bradeneuropeArthur
You can link the parameters from the ipt yo the assembly and visa versa. With the parameter box.
No i logic needed.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 13
I am doing this but we are using vault life cycle process and sometimes i don't want to link because of it.
Message 4 of 13
bradeneuropeArthur
Suppress your link to avoid problems with Vault!!!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 13
Brad i am having trouble with suppressing a linked parameter.  Can you help please?
Message 6 of 13
philip1009
Unfortunately the code to make parameter links between files isn't available yet as far as I know.  The only workaround I found if I'm linking dimensions together is to make a sketch in the inserted component itself and make a reference dim.  As long as the same geometry exists in the file that's replacing the component, and therefore doesn't break the sketch geometry, then the copy design in the Vault won't break that link.  Linking or syncing Boolean or text isn't possible in Inventor yet.
If you want to use iLogic to copy parameters from one file to another, that is possible, but it won't update automatically, the parameters will stay the same until you run the same code again.
Philip Martick
Inventor 2018 Pro, AutoCAD 2018, Autodesk Vault Basic 2018
Windows 10 Pro
2X Intel Xeon E5-2630 v4 @ 2.20GHz
16.00 GB of RAM
NVIDIA Qudaro M2000
Message 7 of 13
bradeneuropeArthur
No code is needed.
I will send you an example ASAP.
Maybe I do it tommorow.
Is this ok for you?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 13
Yeah that is great. Thank you for your help.
Message 9 of 13
bradeneuropeArthur
Take a look at the uploaded example.
if you have questions please let me know.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 13
Braden why do you need to create a level detail? Thanks for all your help. Can you go over the work flow a little please?
Message 11 of 13
bradeneuropeArthur
You need it for suppression of the not needed visible part..
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 13
Braden can you send  a screen shot of  the derived part window when doing it please?
Message 13 of 13
bradeneuropeArthur
What do you exactly need?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
