Skeleton Modeling: Need to Select Sketches from within Window
RoyWickrama_RWEI
Advisor Advisor
Message 1 of 8
RoyWickrama_RWEI
In my skeleton modelling, sometimes, I make all sketches visible (without dimensions visible) with a simple iLogic rule.
However, at this point, I need to select some sketches from within the window and make them them invisible. Also, some others to make their dimensions visible.
Could someone help me. I look forward to receiving help.
Replies (7)
Message 2 of 8
bradeneuropeArthur
You can use representations in the part to achieve that. Like sketches on and sketches off.this is a inventor out of the box solution and no coding required.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
RoyWickrama_RWEI
Thanks for the reply.
This is a master sketch for a very huge assembly modelling. Therefore the sketch has a great many sketches and solid bodes as well. View representation does not help because the sketch (or sketches) need to be invisible and dimensions visible are mostly based on the what I need to do next or editing in general.
Rule based solution is ideal.
Please try to help me.
Message 4 of 8
bradeneuropeArthur
You want to do something with the selected sketch in the browser only. So kind of right mouse option for this sketch or what di you need?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
RoyWickrama_RWEI
Thanks for the comment.
I basically do not look at browser unless necessary. I look in the window (the graphics in the window): select, edit, look for variable name in the sketch(es), copy to clipboard (if relevant), etc..
This is faster and a lot easier.
Message 6 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Hoping that below iLogic code would help to select multiple sketches.
Dim oSketches As ObjectCollection
Dim oSketch As Inventor.PlanarSketch
oSketches = ThisApplication.TransientObjects.CreateObjectCollection
While True
	oSketch = ThisApplication.CommandManager.Pick(
		SelectionFilterEnum.kSketchObjectFilter,
		"Select a sketch to hide")
	' If nothing gets selected then we're done
	If IsNothing(oSketch) Then Exit While
	oSketches.Add(oSketch)
End While
' If there are selected components we can do something
For Each oSketch In oSketches
	oSketch.visible = False
Next
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 7 of 8
RoyWickrama_RWEI
Hi Chandra Shekar;
My approach is a little bit different; i.e. I need to select sketch(es) from within window - I hope this is possible!
Attached is a sample solid-body sketch. With all the sketches are visible, I may analyse to know what sketch(es) is(are) needed to continue. At this point, I need to have only those sketches are visible.
This is very helpful to handle large scale complex master sketch.
Request help.
Message 8 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Thanks for providing sample,
Try the following modified iLogic code to hide selected sketche(es).
Sub Main()
Dim oDoc As Document
oDoc = ThisDoc.Document
Dim oVisibility As New ArrayList
oVisibility.add("ON - ALL SKECHES")			'0-ok
oVisibility.add("OFF - ALL SKECHES")		'1-ok
oVisibility.add("ON - SELECTED SKECHES")	'2-ok
oVisibility_IP = InputListBox("SELECT FROM ABOVE!", oVisibility, oVisibility.Item(0), "SELECT", "VISIBILITY CONTROL")
'oInput = InputRadioBox("SELECT:", _
' "Turn ON - All", _
' "Turn OFF - ALL", "False", "VISIBILITY CONTROL")
Select Case oVisibility_IP
Case oVisibility(0)
	oVisibility_On()
Case oVisibility(1)
	oVisibility_Off()
Case oVisibility(2)
	oVisibility_SelectedSketches()
End Select
For Each oWorkPlane In oDoc.ComponentDefinition.WorkPlanes
If oWorkPlane.Name = "XY Plane" Then oWorkPlane.Visible = False
If oWorkPlane.Name = "XZ Plane" Then oWorkPlane.Visible = False
If oWorkPlane.Name = "YZ Plane" Then oWorkPlane.Visible = False
Next
iLogicVb.UpdateWhenDone = True
End Sub
Sub oVisibility_On()
    For Each oSketch In oDoc.ComponentDefinition.Sketches
    oSketch.Visible = True
    oSketch.DimensionsVisible = False
    Next
End Sub
Sub oVisibility_Off()
    oSketch.Visible = False
    Next
End Sub
Sub oVisibility_SelectedSketches()
Dim obj As Object
While True
	obj = ThisApplication.CommandManager.Pick(
		SelectionFilterEnum.kSketchDefaultFilter,
		On Error Resume Next
		oSketch = obj.Parent
	If IsNothing(obj) Then Exit While
End While
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
