VBA event on part selection change?
I'm trying to write a Macro that would manipulate a part the user selects.
Envisioned work flow within an assembly:
1) Start the macro.
2) A form opens with a blank list (non-modal) form.
3) User can click on parts in either the main window or model tree?
4) On-click parts are added to the list on the form?
5) Some action is performed to the parts in the list.
Is this doable? Any examples around?
Boris.
bradeneuropeArthur
yes that is possible.
hint:
ThisApplication.CommandManager.pick
listview.items.add(from the commandmanager)
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
